2025 TAG Heuer Formula 1 "re-issue" Solargraph (WBY11XX series)
I contacted TH months ago regarding the color blue. It was said the blue strap (FT8105) will be
slightly different than the WBY1112. Since the dial is also a different blue than the bezel, I'm going to
give it a try. I tried a black one and indeed it felt very comfortable.
Plus the strap is separated from the other blues by the steel case, so I think it'll be fine. 馃憣
Kind of like a modern day 370.513.
Yes, and I think that鈥檚 the issue with the McLaren/ Singapore - they are the only 2 plastic ones with the strap the same colour as the case so any difference will be more obvious. In any case, unless it鈥檚 a compete mis match, I think I鈥檒l be fine with it.
On a separate note, my AD who usually quite accurate on these matters reckons there is a 10th coming out around Christmas time. I wonder if it will be a senna type one, or maybe the red bezel from the clock will get a run out.
Hmmm, a Senna 44mm F1 Chrono is rumored for around the time of the Brazilian GP, but no hint of a Senna F1 Solargraph yet. What could it be? 馃
It will be a 10th F1 for Dubai and it has pink highlights like the pink Monaco from a couple of years ago.
Pink and grey/black?
Maybe something like the ref 377 original?
I noticed that the hour marker indices on the red McLaren also seem different from the similar WBY1111. The McLaren has sort of a fauxtina color to the markers. Perhaps to mimic the vintage look of the OG.
I've also noticed more differences in the dials. The WBY1111 and Silverstone have full color logos, while the McLaren and Monza both have monochrome logos like their original counterparts. The WBY1111 has a red seconds hand and white indices within the red ring, while the McLaren has a black seconds hand and black indices within the red ring, exactly like its OG counterpart.
Yes, it鈥檚 like this in person too. Very slight difference
My guy hinted that it was a black DLC case with pink accents
Sounds similar to the 44mm F1 Chrono that was shared in the new F1 Chrono thread.
@Anthony. do you know for sure it's a plastic F1?
Never mind; preorder placed.
You don鈥檛 miss a beat, well done!
How many of these do you already have or intend to get?
Hahaha....I suspect you've now seen it. 馃槀馃槀
I have not seen it, but the color combo sounds nice. 馃槣
I have the 1st, the two Monzas (all red, and tricolore), the blue Singapore soon, and this next one.
Great, nice choices! 馃憦馃憦馃憦馃憦
For some reason, I thought you'd get the all black Miami and yellow/black Mexico too.
