flawless
·Anyone else struggle with getting the screw pins out to size the black ceramic bracelet? The AD I went to handed it back to me. The nearest boutique is 70 miles away.
You could put it in an ultrasonic cleaner (with heat) to help - the screws have threadlock on them, which is designed to counter vibration causing the screws to come loose, but I found a minute in the ultrasonic made it easier. Make sure you have the largest flathead you can fit in the screwhead without scratching the sides of the link, apply force and slowly unscrew (the end opposite the screw has flat sides that mate with the inside of the hole and prevent it turning).
I'm going to contact TAG and see if I can buy replacement screws, as they can still get damaged.
