Hubert
··TAG Heuer Forums Moderator^ I fixed your links.
I got a response from a person with the title of Resolution Specialist from Tag in the LVMH Watch & Jewelry USA, New Jersey office with the following guidance...This was Monday Sept 9th.
The program is now limited to just the Calibre 5 Mechanical Watch exchange...no other options exist anymore.
I am Canadian and this is the new pamphlet that they are using to market the program to their dealer network. See the image below. The same applies to all US dealers (cause I asked what happens if I go to the states and do the switch there).
Timelines, I was told will be near the end of October to Mid-November to expect the new watch to arrive....good news, I don't have to send in my Connected watch until they get in touch with me that my watch has arrived. I also will not be charged anything until that time.
SO I am about to embark on the journey to make the switch!!!!
My Question to the forum....anyone know if the strap from the Connected is interchangeable with the Calibre 5 Mechanical???
I sprung an additional amount way back to get the Tan Leather strap and wanted to know if I can keep it and use it with the Mechanical 46MM.
From the pics I have seen it looks like its a possibility, but I have not confirmed this myself since I've not been able to see the Mechanical watch in person? Any guidance will be much appreciated.
My recollection is that the 46mm Calibre 5 exchange module will not fit the 45mm Connected Modular straps.
I thought the 1st generation Connected was a 46MM? (I don't have my box and paperwork in front of me at the office to confirm this, will check later this evening)
If the exchange mechanical watch is also a 46MM, I would imagine then it is a possibility, No??
Based on pics it looks like position of the lugs on the Connected and the mechanical watch are very similar in shape.
Yes, the 1st generation Connected was 46mm, and the first exchange mechanical watch was also 46mm... BUT in the pamphlet you attached, the mechanical watch on the picture is the Modular mechanical watch 45mm from the 2nd generation (but the name and reference number in the pamphlet is from the first gen). In my previous post I attached pictures of both versions.
So there is a mistake in the pamphlet: in the picture or in the text/reference number. If you receive the watch like in the picture (the Modular 45 mm) for sure the straps will be not compatible with the 46mm, but lf you receive the watch like in the text (the 46mm), then there’s a possibility
Ahhh I see, I honestly couldn't tell the difference from the pictures you had posted. They both looked exactly the same to me, so thank you for clarifying.
