Android P / Next Wear OS News
Finally I have the new update! 馃榾
Which one. The one from 1.5 to 1.6 or the brand new 2.x one?
was it pushed or did you go get it via play store or system updates?
I think it was pushed .. I had to restart my watch though
I tried to force update via play store but it took my watch from 1.5 to 1.6 today. I want 2.0 too 馃檨
You already got 2.0 update .. do you know which security patch you got ?
Uninstall your Wear OS app update from your watch in the play store, and then install it again. I received the 2.0 by doing this. First time running with the new version, the watch was slow, but after switch off/on once more, now it works perfect!
How do you connect to Wi-Fi ? I see on your fifth picture you got Wi-Fi icon !!
It鈥檚 because the watch is on the charger! Then it automatically connects to Wi-Fi.
When not on the charger, you have to switch off the phone鈥檚 Bluetooth if you want that Wi-Fi connection in the watch
It鈥檚 because the watch is on the charger! Then it automaticly connects to Wi-Fi.
I do not entirely agree with that. I can perfectly connect to wifi when my watch is on BT. IT just doesn't connect automatically but manually, i have no issue connecting to my home network.
I am on security patch July 5, 2018
Same here
I have been on that security patch for quite some time now but Wear OS is 1.6, not 2.0
Restart your watch then check your watch .. I had the update in notifications
Ok, maybe it鈥檚 because I share internet by BT from my iPhone with the watch, and then the watch doesn鈥檛 automatically connect to Wi-Fi when it鈥檚 on BT with the phone... if I switch off my phone鈥檚 BT, then the watch automatically connects to Wi-Fi, otherwise it鈥檚 not so easy
